SAB Bröckskes
OCT solutions for servo and motor cables
© SAB Bröckskes
SAB Bröckskes has developed application-specific product series for hybrid and One Cable Technology (OCT) cabling for industrial Ethernet cabling.
With the low-capacitance hybrid motor connection cable of the 'SL 875 C' series, the special cable manufacturer has cabling solutions for Sick Hiperface DSL and Heidenhain HMC6 in its range. Adaptations to other standards can be produced on this basis as required. The model variant specified for Hiperface is available as standard in ten versions with outer diameters from 9.8 mm to 24.4 mm. There are also four specifications in the Heidenhain standard with diameters from 10.8 mm to 15.4 mm. Robust, hard-wearing cable sheaths ensure that the cables are sufficiently flexible and stable to permanently withstand tight bending radii, even with minimal wire cross-sections up to AWG 30. To achieve the lowest possible capacitance, SAB Bröckskes has replaced the classic PVC insulation with low-capacitance insulation materials made of PE or PP. Additional small shielding capacitances enable low-loss transmission. For optimum EMC protection, the motor and servo cables have double shielding consisting of braided shielding and an aluminum-laminated PE film. The double shielding enables interference-free operation of frequency converters.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
Igus
Billion in sales maintained
Despite the challenging geopolitical and economic situation in 2024, Igus was able to increase the number of active customers by 5%. With sales of € 1.105 billion, the company recorded a comparatively moderate decline in sales of 2.5%.
