Phoenix Contact
Designed in protection class IP65/66/67
Phoenix Contact is adding managed switches for field installation to its range of Ethernet switches.
Managed switches for field installation from Phoenix Contact
© Phoenix Contact
The device variants FL Switch 2600 and FL Switch 2700 with protection class IP65/66/67 extend the range of the 'FL Switch 2000' product family and facilitate the integration of distributed sensors, actuators, cameras or I/O stations into the network. The slim design enables a wide range of installation locations. Thanks to the flexible M12 connection technology, users can choose between using classic M12 connectors with screw connection and the provider's M12 push-pull quick-locking system.
According to Phoenix Contact, the wide range of functions and the diverse configuration options, for example via mode button or microSD card, round off the range of variants.
Phoenix Contact
Securely wired and plugged in
When developing the M12 push-pull quick connector in accordance with IEC 61076-2-010, the aim was to retain proven features and add innovative ones. As a result, the familiar features of the M12 connector are combined with the functions of push-pull...
Phoenix Contact
Retired CTO
Roland Bent, CTO of Phoenix Contact, ended his professional life on February 28. His core responsibilities will be assumed by CDO Frank Possel-Dölken from March 1, with a focus on the digitalization of Phoenix Contact.
