ICPDAS
Connect end devices automatically
To reduce the complexity of M2M applications and achieve fast results, ICPDAS-Europe now offers pre-configured M2M solutions.
© ICPDAS
It all starts with the CST series, which is used to transmit digital or analog signals in a complementary manner via mobile radio. The packages each consist of two routers and a freely selectable number of I/O data points. Everything is supplied in the package ready for installation.
The fast LTE mobile radio standard is used for communication between the end devices. The machines networked in this way pass on recorded data via 16 digital inputs. Incoming data is available for further processing via 16 digital outputs. Intelligent reactions or simple monitoring tasks can be easily implemented over long distances. The device series is available in different versions, for example with 16, 32 or 48 digital I/Os.
IoT Hotspot
Industry 4.0 needs Wi-Fi 6 GHz
Technologies such as machine learning and virtual reality require fast data transmission. The key to a comprehensive and fast internet connection is 6 GHz Wi-Fi - although the introduction of the new standard is still being debated in Germany.
