Siemens
Meinrad Happacher,
Complete 5G solution for industry
Siemens is launching its first self-developed private infrastructure for the 5G mobile communications standard. The solution is designed to enable industrial companies to set up their own local 5G networks that provide the best possible support for automation applications.
© Siemens
Siemens has developed its 5G infrastructure specifically for the requirements of industrial customers and industrial applications. It consists of a 5G core and a radio access network (RAN): The RAN comprises the Central Unit (CU), the Distributed Unit (DU) and the Rado Units (RUs). Different 5G end devices can connect to the 5G infrastructure and communicate in the private 5G network. The complete 5G solution is also designed for use in harsh industrial environments.
The private Siemens 5G infrastructure is initially available in Germany. Other countries will follow step by step. One pilot customer for the complete 5G solution is the steel group Salzgitter AG from Germany: "We don't want to build just any 5G network, but an industrial 5G that meets the enormous requirements of the steel industry," says Gerd Baresch, Managing Director Technology at Salzgitter Flachstahl.
NTT
Edge computing, 5G and IoT
IoT devices generate information that requires rapid analysis and immediate decision-making. Only the combination of cloud and edge computing with 5G offers the industry the opportunity to optimize its value chains with the extensive data.
Fraunhofer IEM
5G deployment under the microscope
In order to be able to manufacture products more efficiently, flexibly and autonomously in the future, many companies are hoping for 5G mobile technology. But when does the use of 5G really make sense? And what challenges does the technology pose?
5G at the Hannover Messe
Profinet via 5G
Deutsche Messe and Siemens are giving all companies access to innovative industrial 5G technology in the "5G Smart Venue" in Hanover. Siemens itself is presenting the real-time capable transmission of Profinet IO via a 5G network at the Hannover...
