Beck IPC, Hirschmann, NXTGN, SMC
Meinrad Happacher,
A joint IoT project
A team of specialists from Beck IPC, Hirschmann, NXTGN and SMC gave themselves four weeks to implement an IoT project. - The result can be seen at the Beck IPC stand in Hall 9.
Christoph Müller from Beck IPC and project manager of the interdisciplinary team: "In times of Industry 4.0, even more complex IoT projects must be able to be implemented quickly - we have proven that this is possible with our project!"
© Computers&AUTOMATION
The team of four specialists set themselves the goal of remotely controlling a handling system via a cloud. The system was to use self-learning algorithms to enable predictive and automatic maintenance.
SMC provided the basis for the project - the handling system. Hirschmann designed the infrastructure solution, which uses TSN technology to securely transmit data with different priorities and protocols without interfering with each other. This platform enables the simultaneous use of a network by video technology and control technology. Beck IPC developed the cloud technology, which enables communication from the sensor to the cloud and also control of the machine via smartphone. The NXTGN components process the data delivered to the cloud to provide services such as the digital twin and integration into CRM and ERP service processes with access to real-time IoT data. As a result, it is possible to automatically derive both production orders and service assignments using predictive maintenance algorithms. A nice side effect: with the help of Microsoft's business analytics solution - Power BI - meaningful analyses of past machine data can be displayed, and forecasts can be created visually using machine learning algorithms.
The machine is connected to a server in Frankfurt via Beck IPC's IoT protocol. It can be operated using a smartphone, which is also connected to the server via IoT. The smartphone's sensors react to the movements of the hand and transmit this to the cloud in real time. From there, they are forwarded to the SMC positioning system and the movements are executed accordingly.
A digital twin is displayed on the machine using AR glasses. All information is already cloud-based and linked to a CRM system so that customer requests or faults can be responded to quickly.
Start-ups
The 'Automation Hackathon'
At the 'Automation Hackathon' at SPS IPC Drives 2018, seven start-ups had the chance to develop new business models for selected companies in the automation industry in 48 hours. Winner: the start-up Othermo in collaboration with Wago.
Synapticon
Entering the Machine Building Business
Known as a technology supplier to robot manufacturers, Synapticon now plans to offer targeted solutions for machine builders. The kick-off was given at the SPS IPC Drives with the ‚Actilink‘ drive systems and a quick-start package for the production...
Faulhaber
The winding does it!
With the market launch of the new brushless DC motor family BXT, Faulhaber is setting new standards in the field of external rotor high-performance drives. The winding plays a central role in this.
