Products from the field of measurement technology
The EE310 measuring transducer from E+E Elektronik has been specially designed for controlling and monitoring demanding industrial processes. It measures relative humidity and temperature and calculates dew point, frost point and wet bulb temperature, water vapor partial pressure, mixing ratio, absolute humidity and specific enthalpy. Up to four measured values can be displayed simultaneously on the 3.5-inch TFT color display. All settings and fault diagnostics can be carried out directly on the device using buttons. The display also has a data logger function for seamless recording of up to 20,000 measured values per measured variable. The stored data can be shown on the display or downloaded via the USB interface for further processing on a PC. The measuring transducer is available as a wall-mounted or duct version and with various remote sensors. The remote sensors can be used up to 180 °C and in the pressure-tight version up to 20 bar. For quick sensor replacement, the sensors are also available as plug-in versions. According to the manufacturer, a special coating protects the sensor elements from corrosive and electrically conductive contamination. The modular housing design is intended to simplify installation and maintenance of the device.
