Evotron
Telecentric alternator
Evotron is expanding its product portfolio with the TC-23xINF series of telecentric high-performance LED lights.
© Evotron
Packaged in a robust and thermally optimized aluminium housing with IP67 protection, the lights emit telecentric light over an area with a diameter of 23 mm. According to Evotron, with more than 20 W light output, even 1 μs short flashes are bright enough and enable the use of low-light cameras or telecentric lenses. The lights are used wherever measurements or inspections need to be carried out with high precision and telecentric lenses in transmitted light. All features of the 'Lumisens' technology are supported. The integrated light sensor processor works with the digital LED lighting controllers from the supplier's DCC series. In addition to high-speed flash operation, the digital control technology enables features such as monitoring of the lighting parameters, auto-calibration/monitoring of LED brightness and temperature as well as precision and long-term stability of the lighting parameters.
