VMT
Position detection in six degrees of freedom
The VMT 3D vision system from VMT enables the position detection of any object in all six degrees of freedom.
© VMT
The 3D multi-camera system can track robots precisely in terms of position and application without any loss of cycle time, thus enabling handling, transfer or machining processes. Thanks to completely virtual commissioning based on CAD data, VMT 's vision system can be set up before the first prototype is actually available.
During operation, the system provides robots with correction vectors for their path control. These adapt the robot's application paths to the previously measured position deviations. The position detection system can be expanded at any time, for example by adding further cameras or by teaching in new objects or modified detection features.
VMT
Dynamic visual guidance for 6-axis robots
As part of the production ramp-up for the Audi model derivatives of the A3 successor at the Ingolstadt plant, an automated system for the application of primary seals in vehicle doors was put into operation together with the image processing system...
IDS
AI and streaming meet robustness
IDS Imaging Development Systems is expanding its range of AI cameras with the 'IDS NXT oslo'. The model combines artificial intelligence with video streaming and recording functions in a compact, industrial-grade housing.
