B&RThe climate always in view
In control cabinets, the waste heat must be dissipated and monitored as effectively as possible. But is an extra measuring box in the enclosure really necessary for this? A pragmatic approach.
<p>Interface cards for all common communication protocols and a broad portfolio of different I/O modules can be connected to the X20 controllers via a plug-in system. This means that the complete sensor system for monitoring humidity, temperature and vibration in the control cabinet can be accommodated in an X20 module just 12.5 mm wide and seamlessly integrated into an already installed X-20 system.</p> © B&R
