Cameras
Quelle: MaxxVision | Inka Krischke,
Compliant with the GigE Vision standard
MaxxVision is expanding its camera portfolio with two GigE Vision cameras from Sony with 2.4 and 5 megapixels, equipped with the Sony Pregius global shutter CMOS sensors 'IMX249' and 'IMX264' from the XCG-CG series.
© MaxxVision
Both cameras are GigE Vision 2.0 compliant and IEEE1588 compatible. The IEEE1588 standard enables the synchronization of devices such as camera and lighting connected via the network with an accuracy of up to ±1.5 µs. The XCG-CG240/C camera is suitable for applications from VGA to 2.4 MP and, in addition to CMOS technology, offers new possibilities in terms of frame rate and resolution: for example 100 fps at VGA, 48 fps at SXGA (1360 × 1024) and 41 fps at UXGA (1600 × 1200). The 5.1 MP XCG-CG510/C camera is suitable for applications that require more accuracy at high frame rates, achieving 27 fps at full resolution and 90 fps at 2448 × 500 pixels, for example. Both models are available in monochrome and color versions with 8-, 10- or 12-bit pixel formats. With the 'Area Gain' function, a maximum of 16 image areas can be set separately. The trigger counter can be used to count up the trigger signals received. The cameras have various trigger modes such as bulk and sequential trigger.
Basler
The long-standing Basler CEO Dr. Dietmar Ley will be leaving the company at the end of the year and will be succeeded by the current CCO/COO Hardy Mehl. The CTO position will be filled externally by Dr. Kai Jens Ströder.
