SVS-Vistek
Camera family expanded by 25 GigE models
SVS-Vistek has integrated the 25 GigE interface into various industrial cameras in the FXO family, covering resolutions from 1.8 to 24.6 MP.
© SVS-Vistek
The SVS-Vistek cameras use third and fourth generation Sony Pregius sensors. By using SFP28 connections, cable lengths of up to 10 km and data transfer rates of up to 3125 Mbit/s can be achieved, which enables up to 671 images/s depending on the resolution of the camera model used. The FXO models with a 25 GigE version are housed in a milled housing with dimensions of 50 mm x 50 mm x 100 mm. They have a maximum operating temperature range of +60 °C. The integrated strobe controller allows lighting to be controlled via four high-power outputs with up to 3 A without the use of conventional lighting controllers.
Basler
The long-standing Basler CEO Dr. Dietmar Ley will be leaving the company at the end of the year and will be succeeded by the current CCO/COO Hardy Mehl. The CTO position will be filled externally by Dr. Kai Jens Ströder.
