EVT
3D pin inspection made easy
With the EyeVision 3D software from EVT, pins of any shape can be measured and checked for their correct position and wobble circle.
© EVT
The wobble circle inspection carried out by the 3D software checks the deflection of the pins on a lateral plane by means of orthogonal viewing. In addition, 'EyeVision 3D' from EVT also measures the set depth of the pins. The 3D inspection makes it possible to measure the height of the pin tip on the connector. Constant error detection and error measurement guarantee consistent quality.
The PinInspector 2.0 enables a specially optimized process for pin inspection. It offers specially adapted 'EyeVision 3D' software with a ready-made inspection program kit, the EyeScan AT 3D laser triangulation sensor, a compact industrial PC and an optional linear axis. The PinInspector can be used to measure the following connector/pin characteristics: Wobble circle, measurement of the setting depth, measurement of the pins and faults on the connector.
EVT
New GUI Designer integrated
EyeVision Version 4.3 introduces a completely revised GUI Designer to the software, which can be used to graphically compile a variety of displays in addition to statistics.
IDS
AI and streaming meet robustness
IDS Imaging Development Systems is expanding its range of AI cameras with the 'IDS NXT oslo'. The model combines artificial intelligence with video streaming and recording functions in a compact, industrial-grade housing.
Digital Twins
With real-time data against disasters
A digital twin is more than just a two- or three-dimensional digital copy. It combines precise data with intelligent analysis and solves complex challenges. With locations in Paderborn and other cities, Eviden relies on the combination of artificial...
