Products of the year 2020/2021Readers' choice: Who are your favorites?
Smart, innovative, trend-setting - that's what the automation industry was like again this year! We have nominated 96 products in twelve categories and put them forward for your vote as "Products of the Year". Which are the most innovative and useful products for you?
AMO 's encoders measure position values with deviations of less than 1 µm per signal period, which enables precise positioning of robot axes and therefore the safe operation of cobots in close proximity to human workers. The position values determined by the encoders are also redundant - two independent values are generated in the encoder for each measurement. In this way and through the additional transmission of error bits to the higher-level control system, measurement errors are eliminated.
The absolute encoders have been certified for use in safety-related applications.
As a service for robot manufacturers, the encoders have a so-called mechanical fault exclusion: the safe mechanical connection of the encoders to the drive unit of numerous applications has been tested and confirmed by a type examination. This eliminates this process for robot manufacturers. The absolutely functionally safe encoders are equipped with purely serial single-encoder interfaces (EnDat 2.2 or Drive CLiQ).
