Products of the year 2020/2021Readers' choice: Who are your favorites?
Smart, innovative, trend-setting - that's what the automation industry was like again this year! We have nominated 96 products in twelve categories and put them forward for your vote as "Products of the Year". Which are the most innovative and useful products for you?
With the Single Pad Gecko gripper,OnRobot provides a compact version of the 'Gecko' gripper that is particularly space-saving and lightweight. It is designed for three different payloads. Its special holding technology is based on the way gecko feet work and, unlike conventional vacuum grippers, also allows automated handling of perforated workpieces such as drilled circuit boards.
The 'Single Pad Gecko' is available in the SP1, SP3 and SP5 versions, which are named after their respective load capacity in kilograms. The gripping technology is based on the way geckos climb. It works with millions of microscopic hairs that are located on the gripping surfaces. When pressed onto a flat object, they generate adhesion through van der Waals forces. The gripper is particularly suitable for handling flat objects with shiny surfaces such as tiles or displays. It can be attached to any standard collaborative robot arm using OnRobot's One-System-Solution.
