Power supply
The benefits of energy storage systems
High-load time windows and peak loads drive up the electricity costs of many companies. Energy storage systems promise to help reduce costs.
The energy transition has resulted in fundamental changes to the energy market. Among other things, the focus is on the use of renewable energies and their integration into the existing supply while maintaining grid stability. In the liberalized energy market in Germany, the Electricity Grid Charges Ordinance, which came into force in 2005, specifies the method by which the respective grid usage charges are determined. Individual grid charges for high-load time windows and peak loads, which industrial grid customers must take into account in their calculations, are playing an increasingly important role. As a rule, medium-sized and larger companies with high electricity consumption are managed by the energy supply companies as special contract customers and are subject to power metering, which records electricity consumption in 15-minute time windows.
The annual performance price
Electricity suppliers must provide the maximum amount of energy that a company requires. The provision of this capacity is paid for via a so-called annual capacity price - even if it is only called up during certain periods. The annual capacity price is based on the peak load that occurs in a 15-minute time window and is recorded by a meter in the corresponding measuring interval. This peak load as the maximum measured electricity consumption in this time window is used as the measured active power for calculating the demand charge. The demand charge for the relevant billing period is applied if the agreed basic energy consumption is exceeded in an agreed period. For this purpose, the maximum 15-minute output in kilowatts measured in the contractually agreed period is multiplied by the demand charge in euros per kilowatt and year. Depending on the peak load, this can result in considerable additional costs. If the consumption peaks are reduced, the costs also fall.
Reduce the performance price
Active load management with the shutdown of non-critical consumers is not possible in every industrial application: in chemical processes or industrial production processes, it is often not possible to optimize consumption or even switch off energy-intensive consumers.
This is where an energy storage solution, such as that offered by Socomec, comes into its own. Here, load peaks are fed from a specially integrated energy storage system without recourse to the energy supplier.
Electricity storage and the EEG
In Germany, the Renewable Energy Sources Act (EEG) has so far hindered the use of electricity storage solutions due to the double burden of the EEG surcharge. This serves to reimburse the grid operators for the difference between the feed-in tariff for the generation of renewable energy and the lower price for the sale on the electricity market. It is paid by the end consumer. In the case of storage, the surcharge may be due twice: when storing and when withdrawing, provided the stored electricity is not fed back into the grid.
Since the beginning of 2017, the new version of the EEG - the EEG 2017 - has improved the situation by exempting storage facilities that are operated for self-supply, for example, from the double charge. The EEG surcharge is waived for storage losses and for injection to the extent that it is paid for the electricity withdrawn from storage. Proof is provided by recording all electricity volumes.
Know your own load profile
The basis for capping peak loads is the recording and evaluation of energy consumption, for example with the 'Diris Digiware' measurement solution from Socomec.
© SocomecThis elimination of the double levy paves the way for storage solutions for peak load capping in Germany. The prerequisite for using this method is knowledge of the individual load profile. A basis for the application of the energy storage solution is therefore the analysis of the causes of electricity consumption:
First of all, those responsible for planning or operations management must determine how much energy is requested and consumed in the company and when. This is done using a measuring device with power measurement. In order to record consumption accurately, the operator must ensure that the metering solution monitors the electricity consumption of as many consumption-intensive points in the company as possible. Only then is further evaluation possible, providing information on the extent of load overruns and indications for reducing and optimizing electricity consumption. By implementing suitable measures to reduce peak loads, companies can then reduce their annual electricity costs.
Smoothing load peaks
An energy storage solution on a Californian university campus: peak values are capped.....
© SocomecIn the USA, Stem - a provider of intelligent energy storage solutions and energy management software - is implementing such projects. The company uses energy storage systems that are controlled by the energy management software developed in-house in such a way that the load peaks of the consumer companies are determined and compensated for. To do this, an energy storage system is charged during times when the application consumes little power and releases the energy again during times of high energy demand. The system solution makes it possible to reduce the peak energy demand from the energy supplier and thus optimize the electricity bill.
....'Sunsys Xtend ESS' from Socomec feeds peak loads from a specially integrated energy storage system.
© SocomecFor the energy storage solutions, Stem uses a solution from Socomec's portfolio: 'Sunsys Xtend ESS' is an integrated system with UL1741-compliant 'Sunsys PCS²' battery inverters, cabinets with overcurrent and short-circuit protection devices and therefore all the necessary protection devices for safe operation and maintenance, as well as lithium-ion batteries.
In 2016, Stem realized the largest energy storage installation in building technology in the USA with 1.3 MW. With another energy storage system from the manufacturer, Stem is enabling a university campus in California to reduce its peak value by 345 kW, which corresponds to a monthly saving of over 6,200 US dollars. With this savings potential, the investment costs can be amortized within a short period of time.
Socomec's ESS solution follows the charging and discharging profiles set by Stem's software solution to reduce peak consumption.
The solution can also be used to supply loads with renewable energy generated by the user company itself. Surplus energy is stored or fed into the grid. Isolated operation is possible in the event of a grid failure. For example, a system installed in the transformer substation with the 'Sunsys PCS² IM' battery inverter can autonomously supply the affected island in the event of a power grid failure, a fault or an intended load shedding.
Author:
Steffen Breiter is Marketing Manager Germany/Austria at Socomec in Mannheim.
