Cosel
Series of flat open-frame power supply units extended
Cosel has expanded the LHA series with two compact open-frame power supply units for demanding industrial applications.
Cosel has added two compact open-frame power supply units to the LHA series
© Cosel
According to the manufacturer Cosel, the LHA10F and LHA15F power supply units are 15 % smaller and offer a 50 % lower leakage current than conventional products on the market. They can be operated in a wide temperature range from -10 to +70 °C and are UL/EN62368-1 certified. Designed for worldwide applications, the power supply units have an input voltage range of 85 to 264 V(AC) single-phase and comply with the input voltage range of the safety standards of 100 to 240 V(AC) (50/60 Hz). They are available with five output voltages: 3.3 V, 5 V, 12 V, 15 V or 24 V with the corresponding currents. For both versions, the 3.3 V output voltage can be set in the range from 2.85 V to 3.63 V, all other voltages are factory-set. The efficiency is specified as up to 84.5% at 230 V(AC) and nominal load. The devices have an inrush current limiter, overcurrent protection with automatic restart and overvoltage protection.
Eaton
UPS with high efficiency
The '93T' uninterruptible power supply (UPS) from Eaton has a rated output of 15 to 80 kVA and provides a stable power supply for critical applications such as server rooms and small data centers.
