Schneider Electric
Available with up to 600 kW UPS capacity
Schneider Electric is expanding its range of 3-phase UPS systems: The Easy UPS 3L series supports the operation of external battery cabinets and is available in various power sizes from 250 to 600 kVA (400 V).
Critical devices in a variety of environments are protected from damage caused by power failures, surges and voltage peaks. The UPS systems achieve an efficiency of up to 96% in double conversion mode.
In addition, the Schneider Electric series offers a wide battery voltage window and is therefore suitable for a variety of battery configurations. Depending on requirements, up to five UPS systems can be installed in parallel to increase capacity or to implement 5+1 redundancy. If a power block fails, the load is automatically distributed to the remaining power blocks, provided the load is below the capacity of the functional power blocks in the overall system.
