Schneider Electric
Available with up to 600 kW UPS capacity
Schneider Electric is expanding its range of 3-phase UPS systems: The Easy UPS 3L series supports the operation of external battery cabinets and is available in various power sizes from 250 to 600 kVA (400 V).
© Schneider Electric
Critical devices in a variety of environments are protected from damage caused by power failures, surges and voltage peaks. The UPS systems achieve an efficiency of up to 96% in double conversion mode.
In addition, the Schneider Electric series offers a wide battery voltage window and is therefore suitable for a variety of battery configurations. Depending on requirements, up to five UPS systems can be installed in parallel to increase capacity or to implement 5+1 redundancy. If a power block fails, the load is automatically distributed to the remaining power blocks, provided the load is below the capacity of the functional power blocks in the overall system.
CUI
Power from 35 to 350 W
CUI, a Bel Group company, is expanding its 'VGS' range of single-output AC/DC chassis power supplies in compact metal housings with the three series VGS-C, VGS-D and VGS-W.
Review
The top articles in February 2023
In addition to annual trends and new developments, the topic of security and how to maintain it played a key role in our most-read articles of the past month. Find out which negative headlines also made it into the ranking here.
