Pulse
22.5 mm wide electronic circuit breaker
The electronic 4-channel circuit breakers (ECBs) 'Pisa-M' from Puls are aids for protection and power distribution in applications with power requirements from 90 W to 480 W.
© Pulse
The digitally coded interface in the circuit breaker makes it possible to remotely control the electronic circuit breakers and monitor the operating status of the system. The power distribution can thus be managed via a PLC and a central user interface. At 22.5 mm wide, Pisa-M is the smallest electronic circuit breaker with four channels on the market, according to the manufacturer Puls. The connectors on the front of the module enable tool-free installation, while two-color LEDs indicate the status of each output channel in real time. Each output channel can be switched on and off or reset via a button.
There are different device versions: The 4ADJ modules are adjustable. Each output channel can be flexibly set to the required current value from 1 to 8 A. If a plug-and-play device with fixed current values is required, variants with 2 A, 4 A, 6 A and 8 A are available.
Pulse
Acquisition of Wiferion
Puls takes over Wiferon and thus all existing contracts, trademark rights and patents of the wireless charging specialist. In the medium term, users will benefit from Puls' global production capacities.
Eaton
UPS with high efficiency
The '93T' uninterruptible power supply (UPS) from Eaton has a rated output of 15 to 80 kVA and provides a stable power supply for critical applications such as server rooms and small data centers.
