Fiber-optic distributor
Use it indoors and outdoors
From Telegärtner comes a flexible distributor for fiber-optic cabling - the robust and space-saving TOC ODB 68 distributes and protects fiber-optic connections both indoors and outdoors in harsh environments.
© Telegärtner
Applications range from cabling infrastructure for buildings and FTTH networks through mobile communication or industrial applications and security engineering to smart grid. The IP68 graded watertight casing can be fitted to walls and ceilings, installed in the ground and on masts.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
