Industry 4.0
Olaf Graeser | Inka Krischke,
The 'SEAP 4.0' project
I4.0 has been accompanying automation technology since 2011. The main results of this work are the Reference Architecture Model Industry 4.0 (RAMI 4.0), the I4.0 component and the asset administration shell. The concept of the asset administration shell has now been implemented.
© Phoenix Contact
Industry 4.0 components consist of real objects (assets) and their representations in the digital world (AAS).
© Phoenix Contact
Even if numerous interesting projects from research and industry presented individual aspects of Industry 4.0 in a striking way, a practical implementation of the administration shell was lacking for a long time. This has changed with the open source project 'openAAS' (open Asset Administration Shell) by ZVEI and the Chair of Process Control Engineering at RWTH Aachen University. This project aims to test the feasibility of the previously purely theoretical administration shell (AAS) using a practical implementation. In this way, a basis for discussion for further developments is to be created. With openAAS, the first administration shell was designed that meets the requirements of the Industry 4.0 platform.
End-to-end engineering
In the 'SEAP 4.0' project, the first step is to transfer files in the BMECat (eCl@ss) format from the component manufacturer to engineering and, as a combination of the AutomationML and eCl@ss standards, to intelligent manufacturing.
© Phoenix Contact
In a collaborative project called 'Smart Engineering and Production 4.0' (SEAP 4.0), the companies Eplan, Rittal and Phoenix Contact are tackling the challenge of end-to-end engineering. Using the example of enclosure construction, the partners are demonstrating the importance of digital models for engineering and production. In the 'SEAP 4.0' scenario, component manufacturers provide digital models of their products - for example terminal blocks - in the form of eCl@ss descriptions. These can then be used directly in the engineering process of the control cabinet. The resulting digital model of the enclosure can then be used immediately for intelligent production on the basis of the eCl@ss and AutomationML standards.
Originally, files were transferred in the 'SEAP 4.0' project: BMECat (eCl@ss) from the component manufacturer to engineering and a combination of the AutomationML and eCl@ss standards to intelligent production. The next logical step in the project was to use the latest Industry 4.0-compliant technology to transport information between the systems. This is where openAAS comes into play.
In the 'SEAP 4.0' scenario, openAAS is used in three different scenarios: the provision of article data for engineering, the comparison of system capabilities for intelligent production and the management of configuration data.
Article data for engineering
For the first use case, the eCl@ss-based item data was modeled in openAAS asset administration shells. openAAS does not use simple characteristics here, but so-called Property Value Statements (PVS). The PVS enable, among other things, the transfer of the eCl@ss identifiers (IRDIs) and also create an attribute statement for the characteristics. The characteristic statement can be a requirement, assurance, measurement or setting. The mapping of eCl@ss information - i.e. catalog data - is always an assurance. For each item used in the 'SEAP 4.0' scenario, a corresponding AAS was generated and stored on a server. In order to be able to import this article information into Engineering, the partners developed a prototype Eplan plug-in that records the data exchange with the article data server using openAAS communication tools, requests and receives an article and inserts it into Engineering's product data management.
Align system capabilities
An intelligent control system determines the available manufacturing capabilities of the production system. It distributes the submodels of the product to be manufactured to the individual systems so that production can begin.
© Phoenix Contact
Ideally, asset administration shells should run directly on your asset. If this is not possible, proxy asset administration shells can also be outsourced. In this case, the interaction between the asset and the asset administration shell is realized via smartphone.
© Phoenix Contact
In the second scenario, data is exchanged between the intelligent control system and the connected production facilities. Initially, only the production systems were equipped with openAAS administration shells. The associated control system communicates directly with the AAS via OPC UA. In the first step, the production control system receives the digital model of the product to be manufactured as an AutomationML file from the engineering department. It then derives the necessary production steps from the digital model on the basis of rule-based closing. The AAS of the production systems contain, among other things, the production steps available in the respective system as an assurance. The control system then queries the available production steps from all connected AAS. If the required and available production steps match, the control system distributes the submodels of the product to be manufactured to the individual systems and production can begin.
In addition to the production steps, the capacity utilization of the systems is to be taken into account in future. In this way, the control system can not only decide whether the product can be manufactured, but also by when. This approach allows the customer to submit a digital model of the desired product as a request to the manufacturer's web platform via a configurator or an engineering tool. From there, the digital model is sent via the ERP system to the production control systems, which can then independently determine whether and by when the product can be produced. The result is reported back to the ERP system, which adds the price of the product to the information. In this way, the customer receives information about the delivery date and costs within a short time.
Manage configuration data
The third use case deals with the topic of proxy asset administration shells. Ideally, the AAS is located directly on the asset, but this is not always possible. In the 'SEAP 4.0' scenario, a power supply serves as an example. Although the device can be configured via NFC (Near Field Communication), it is otherwise not capable of communication apart from signaling outputs. In this case, the corresponding AAS can also be located elsewhere, for example in the system operator's IT system. However, it must be possible to establish a connection between the AAS and the asset. For this purpose, the configuration app for the power supply has been expanded so that it can take on this task. The configuration data read in via NFC is now forwarded from the app to the AAS via WLAN or mobile radio. For this purpose, all configuration features are fully modeled as PVS within the AAS.
However, if the data in the asset administration shell changes, the app receives the new data from the AAS and the user is prompted by the app to transfer the update to the asset. In this way, the configuration states in the AAS and the asset always remain synchronized. The advantage for the system operator is that configuration no longer has to be carried out via a special app. It is also possible to make changes directly in the AAS from any location, although this requires transmission via a mobile device. In order to transfer live data from the power supply to the AAS, the 'SEAP 4.0' project chose the route via a controller. For this purpose, the signal outputs of the power supply were connected to the inputs of a fieldbus system whose controller is connected to the AAS via OPC UA and continuously sends updated data to it.
Author:
Olaf Graeser is an employee in the Corporate Technology & Value Chain department at Phoenix Contact in Blomberg.
Describe ideas of the administration shell
openAAS is one of the first projects to deal with the realization of a real administration shell in accordance with the concepts of the Industry 4.0 platform. The result is a prototype that is very well suited for testing and as a basis for discussion for further approaches. The most important work is the 'Administration shell in detail' and 'Administration shell in concrete terms' documents. They aim to describe the idea of the Administration Shell in such a way that it can be implemented by development teams. Different focal points were set: The document 'Administration Shell in detail' defines the metamodel, i.e. technical details such as the structure, identifiers or features. In contrast, the 'Administration Shell in Concrete Terms' deals with the content of submodels, for example the definition of overarching basic submodels or the independent development of submodels by users. Industry 4.0 is thus developing from an abstract idea into a realizable technology.
Circuit breakers
The transparent power supply
Transparency in the production process requires the continuous recording of measured values and their forwarding to the control systems. The example of a modern automatic circuit breaker shows what this can look like in the field of 24 V (DC) power...
Smart cameras
Optimized production
Covering three tasks with just one visualization system - this was the requirement when redesigning a bag filling system for the food industry. Smart camera technology makes it possible.
Control software / simulation
Automate the test
Machine and system manufacturers are increasingly moving towards simulating control software before commissioning in order to correct any errors in advance. Instead of carrying out the tests manually as before, it is advisable to switch to an...
Industry 4.0
From the sensor to the cloud
How can sensor data be uploaded to a cloud platform? At SPS IPC Drives, Hilscher is presenting a technology platform that is intended as a system solution for OEMs and also includes the aspects of diagnostics and maintenance.
Industry apps
Digital prototyping
Digitization projects are often viewed with scepticism. This makes it all the more important to involve employees in new workflows and processes right from the start. Rapid prototyping methods and processes are suitable for this - for example when...
Safety mats
Operation by foot
Safe area monitoring combined with active machine operation - this is exactly what a dynamic safety mat offers. Workers can trigger defined actions using their feet and virtual buttons. Their hands remain free, enabling new operating concepts.
Industrial PCs
20 % more productive
Flying chips, vibration and splash water: industrial PCs have to cope with such influences in the production of clamping tools. With BDE and CAD software on board, they increase productivity by 20 %.
