Rittal
Smart filterfans
Filterfans are the most commonly used solution for climate control. Rittal is now making this seemingly simple technology smart. The EC filterfans can be recorded via the Rittal IoT interface.
© Rittal
In addition to information on status, utilization, operating hours or energy consumption, there is also a temperature alarm. Temperature sensors can be attached to the most critical points and assigned to the correct filterfans via the IoT interface. If the temperature rises above an unplanned alarm threshold, the system operator is informed and the filter fan's emergency cooling function is activated. During automatic filter cleaning, the Rittal filter is lightly blown out several times a day to remove fine dust particles. This extends the service life of the pleated filters. Operators can also enter a virtual operating time to suit the respective environment. The system indicates when the next filter change is required depending on the running time and speed. This enables maintenance on demand instead of at fixed intervals.
Rittal
Megawatt cooling developed for AI
Rittal has developed a cooling solution that delivers over 1 MW of cooling power and paves the way for artificial intelligence. This is because the demand for computing power is growing so rapidly that a new level of scaling, cooling, power...
Rittal
Interior door for double security
Rittal is launching a new series solution for internal doors. The accessory extension, which is available for AX plastic enclosures and AX compact enclosures in sheet steel, can be installed in the enclosure as a second level and control panel.
Review
The top articles in March 2023
The most-read articles in March are characterized by technical innovations in digitalization, practical application examples and tips on HMI as well as award winners in the field of embedded solutions. Also included for the second time: brazen...
Rittal
The three twins
The goals of digital transformation in industry are clearly defined: more transparency, knowledge and speed. Now three digital twins - of plant, product and production - and their networking are making possible in practice what has long been...
ZVEI
Rittal wins Electrifying Ideas Award 2026
The ZVEI has chosen Rittal as the winner of the Electrifying Ideas Award 2026. With this award, the German electrical and digital industry honors innovations and solutions that use energy efficiently, conserve resources and have an economic and...
Rittal
Air cooling is no longer enough!
The demand for computing power, especially for AI, is growing so rapidly that a new level of scaling, cooling, power distribution and energy efficiency is required in data centers. Philipp Guth, CTO of Rittal, explains the need to switch to water...
