Hebotec
Shield clamp with crimp cable lug
There is a new addition to the shield clamps from the Hebotec 'Heboclip' system: a shield clamp with crimp cable lug in different versions in the clamping range from 1.5 to 30 mm.
Umbrella clips from the 'Heboclip' system from Hebotec
© Hebotec
At the base of the Hebotec clamp is a cable lug that can be used to flexibly crimp on an earthing cable. The cable lugs are available in three sizes: red ones accept strands from 0.5 to 1.5 mm2, blue ones from 1 to 2.5 mm2 and yellow ones from 4 to 6 mm2. The shield clamp is also available in a version with a strain relief clip, so that the cable can also be secured with a cable tie over the cable sheath if required. The cable shield can be pressed in from above and released again just as easily. The rounded edges of the shield clamp prevent cables and wires from chafing. A 'Heboclip' system consists of a support plus matching shield clamp. All sizes of umbrella clip and all shapes that are suitable for clipping can be attached to four different universal brackets.
SPS 2021
E-Paper THE OFFICIAL DAILY Day 2
Today's fresh issue of THE OFFICIAL DAILY Day 2 has plenty of news for you and keeps you up to date with all the trends and developments in the industry. The "Click-here" button will also take you to additional features. Try it out for yourself.
