Polyrack
Modular for mounting rail and wall mounting
The products in Polyrack's 'Railo' series are suitable for holding PCBs and Eurocards as well as for fitting individual electronics or backplanes, which can be inserted into the grooves provided in a stable and torsion-free manner.
Thanks to its robust design, EMC preparation and flexible front design options, the Polyrack series offers a wide range of possible applications. The three-dimensional expandability of the external dimensions allows for customized adaptations. The series meets quality standards and norms (EN 60715) thanks to the use of high-quality aluminum and stainless steel as well as IP20/IP30 certification. The basic structures of the series are available in two versions: as a basic profile with a height of H1 = 111 mm to accommodate a single Eurocard (100 mm) and as a basic profile with a height of H1 = 133 mm to accommodate a PCB (122 mm). Various options are available for the front design, which can also be individually designed and processed - for example with front cover, with side panel and front panel, with side panel for wall mounting and front panel or with separate height expansion panel.
