Siemens
Peripheral devices according to protection class IP65/67
With the Simatic ET 200eco PN, Siemens is launching a new generation of machine-oriented block peripherals onto the market. The I/O family in protection class IP65/67 initially consists of five digital peripheral devices and an IO-Link master device.
© Siemens
The industrial metal housing protects the devices against UV radiation and pollutants, allowing them to be used outside of factory halls. The devices are powered via an L-coded plug, which means that longer cable runs can be covered in the field and energy-intensive components (such as valve terminals) can be supplied and switched without having to carry additional power supply cables.
The peripheral devices have individually parameterizable M12 sockets and support S2 redundancy. Users can access the current switching status of the inputs or outputs of a module simultaneously and independently from several controllers using 'Module-internal Shared Input' (MSI) or 'Module-internal Shared Output' (MSO) without any additional programming effort.
Eplan
The benefits of data standards
Fully digitized data is the driver for optimizing engineering in control and switchgear construction on the basis of a digital twin. This means that the corresponding article and device data must be available right at the start of project planning.
Siemens
The Logo! on the cloud
Automation with a cloud connection - a complicated undertaking? Not necessarily: In combination with Logo! 8, implementing simple automation tasks via the cloud can be really fun.
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
