Pflitsch at the SPS 2023
Modular cable entry system
With the modular and easy-to-install CABseal series from Pflitsch, pre-assembled cables and wires can be easily and safely inserted into control cabinets and housings.
'CABseal' consists of four frame sizes - suitable for the usual standard cut-outs in switch cabinet construction up to 115 mm x 46 mm. These frames can be variably equipped with four, six, eight or ten grommet fields, so that a maximum of 40 cables with a diameter of up to 6 mm can be reliably sealed. The tongue and groove contour of the cable grommets prevents incorrect installation and ensures stability.
Cable grommets with flexible sealing lip geometry are available in GS sizes for cables from 3 mm to 16 mm in diameter and as GL for 16 mm to 33 mm. Single, double and quadruple grommets enable a high packing density. The grommets can be positioned anywhere in the frame. The large sealing area and the flexible sealing lip geometry can compensate for cable tolerances of up to 0.4 mm and ensure that the cable is sealed to protection class IP66/UL Type 4X. An internal strap can be used with cable ties to increase strain relief and securely fix the installed cables.
The CABseal frames made of glass fiber-reinforced polyamide have a molded elastomer seal so that no additional flat seal is required at the housing cut-out. The installation height of 20 mm results in a space-saving installation. Flush-fitting grommets ensure a continuous closed surface without beads or edges.
The Pflitsch cable entry system is suitable for indoor and outdoor applications in the temperature range from -40 to +100 °C. The materials are halogen-free, silicone-free and UV-resistant, comply with current RoHS regulations and fire protection class UL 94: V0. CABseal is also UL listed. Blanking grommets and plugs round off the portfolio to securely close off unused fields.
Hall 2 Stand 439
