Pflitsch at the SPS 2023
Modular cable entry system
With the modular and easy-to-install CABseal series from Pflitsch, pre-assembled cables and wires can be easily and safely inserted into control cabinets and housings.
The 'CABseal' allows up to 40 cables with IP66 protection to be fed into enclosures and housings.
© Plow
'CABseal' consists of four frame sizes - suitable for the usual standard cut-outs in switch cabinet construction up to 115 mm x 46 mm. These frames can be variably equipped with four, six, eight or ten grommet fields, so that a maximum of 40 cables with a diameter of up to 6 mm can be reliably sealed. The tongue and groove contour of the cable grommets prevents incorrect installation and ensures stability.
Cable grommets with flexible sealing lip geometry are available in GS sizes for cables from 3 mm to 16 mm in diameter and as GL for 16 mm to 33 mm. Single, double and quadruple grommets enable a high packing density. The grommets can be positioned anywhere in the frame. The large sealing area and the flexible sealing lip geometry can compensate for cable tolerances of up to 0.4 mm and ensure that the cable is sealed to protection class IP66/UL Type 4X. An internal strap can be used with cable ties to increase strain relief and securely fix the installed cables.
The CABseal frames made of glass fiber-reinforced polyamide have a molded elastomer seal so that no additional flat seal is required at the housing cut-out. The installation height of 20 mm results in a space-saving installation. Flush-fitting grommets ensure a continuous closed surface without beads or edges.
The Pflitsch cable entry system is suitable for indoor and outdoor applications in the temperature range from -40 to +100 °C. The materials are halogen-free, silicone-free and UV-resistant, comply with current RoHS regulations and fire protection class UL 94: V0. CABseal is also UL listed. Blanking grommets and plugs round off the portfolio to securely close off unused fields.
Hall 2 Stand 439
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
