Conta-Clip at the SPS 2023
Modular cable entry for installation from the outside
According to the manufacturer Conta-Clip, the 'KDSI-SR' inverse modular cable entry system ensures reliable sealing, flexibility and time savings when feeding through cables and wires with and without connectors.
© Conta-Clip
The system from Conta-Clip, designed for confined spaces, can be easily attached to the outside of a control cabinet, housing or machine. As part of the 'KDS Click' cable management program, 'KDSI-SR' also allows flexible retrofitting of existing installations at any time. The intelligent system concept with individually insertable sealing elements enables individual configurations for different numbers of cables and conduits. Completed installations can be easily dismantled, modified in parts and reassembled. Cables with connectors do not have to be laboriously dismantled and reconnected for retrofitting or service work, so that the manufacturer's warranty is retained.
Hall 10.0, Stand 122
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
