Lapp
Lead-free bolting solutions
To complement the existing portfolio, Lapp is presenting the extensive lead-free 'Skindicht' series - blanking plugs, reducers, extensions, adapters and locknuts.
The lead-free 'Skindicht' series from Lapp
© Lapp
All lead-free product alternatives with the LF marking in the article number have the same product properties as the previous variants with a low lead content. The new portfolio includes, for example, the adapter Skindicht MA-PG/M, which enables the transition from a PG external thread to a metric internal thread, withstands temperatures up to +200 °C and is designed for thread sizes up to PG36 or M40.
Lapp offers the Skindicht BL-M blind plug (up to +200 °C) and the Skindicht BL-M hex (up to +100 °C) for sealing an unused metric threaded hole on the housing. Both can withstand high chemical and mechanical loads, are also suitable for outdoor use and can be fitted using a slotted screwdriver or open-end wrench. In the case of the Skindicht BL-M hex, a fitted O-ring enables the liquid-tight closure of the threaded/through hole.
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
