Lapp
Inventory management 4.0
When the cable reel is empty, production comes to a standstill. This is not an unlikely scenario, as many companies can only guess at the remaining quantity of cables in the warehouse. Smart sensor technology for the cable drum rack provides a remedy.
© Lapp
For some time now, Lapp has had the idea of a cable drum that not only monitors the removal of cable lengths, but also automatically reorders if the quantity falls below a defined minimum. Why? Customers had reported to Lapp employees from time to time that they lacked an overview of their own cable stock. One customer, for example, ran out of an important cable at the most inopportune moment, bringing machine construction to a standstill. The company had to pay one percent of the machine value per week of delay as a down payment, which quickly added up to costs of several thousand euros per week.
Due to the recognized needs of the users, the project for intelligent cable inventory management was therefore taken up again and the system called 'eKanban' was further developed in close cooperation with customers.
But how does a cable drum know how much cable it contains? If the warehouse staff at some companies don't know how much cable length is left, how is a wooden drum supposed to know? What sounds like a joke actually kept the innovation team at Lapp busy for quite a while. Initially, distance sensors were supposed to provide information on how much cable had been removed from a drum and how much was left. However, this method proved to be too imprecise. In the second version, the project team used an inertial sensor that measures the revolutions of the drum and calculates the amount of cable removed.
"Instead of 10 to 15 percent inaccuracy, the new technical solution gives us a deviation of ±1 percent - which is more than acceptable for the intended application," says Dominik Schmalzried, Global Business Process Owner Digital Innovation at Lapp. The company therefore patented the solution. It consists of the inertia sensor on the cable drum or axle and a display attached to the drum rack. The main artery is a web-based dashboard in which not only the customer's fitters but also purchasers, for example, have convenient access to all cable stocks from their workstations. The sensors, which have a very long battery life, can be easily retrofitted to existing cable racks and drums. There is also a connection to digital systems from Lapp. The 'eKanban' will also offer interfaces to ERP systems as it is developed to series maturity - in line with the motto: Industry 4.0 for cable inventory management. This means that the system will soon also modernize cable inventory management for racks and reels from other suppliers.
Automatic reordering
The display attached to the drum rack shows the current cable inventory.
© Lapp
The system can be configured and controlled on a digital dashboard. Users can always see the fill level of all cable drums almost in real time. They can also set a threshold value for automatic orders. If the system is connected to Lapp, the order date can be set up flexibly: The data collected by the sensors helps to predict how much cable length will be used in a given period. The system checks in the Lapp system how long a delivery will take at this time. By comparing the consumption and delivery forecast data, the system can then schedule the reorder so that replenishment is available on time.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
Igus
Billion in sales maintained
Despite the challenging geopolitical and economic situation in 2024, Igus was able to increase the number of active customers by 5%. With sales of € 1.105 billion, the company recorded a comparatively moderate decline in sales of 2.5%.
