Industry 4.0The 'SEAP 4.0' project
I4.0 has been accompanying automation technology since 2011. The main results of this work are the Reference Architecture Model Industry 4.0 (RAMI 4.0), the I4.0 component and the asset administration shell. The concept of the asset administration shell has now been implemented.
<p>Ideally, asset administration shells should run directly on your asset. If this is not possible, proxy asset administration shells can also be outsourced. In this case, the interaction between the asset and the asset administration shell is realized via smartphone.</p> © Phoenix Contact
