24 of 25
Slim-dimensioned cooling unit series from Seifert Systems
© Seifert Systems
Seifert Systems is launching a slimline cooling unit series with cooling capacities from 300 W to 6 kW. With its space-saving design, the SlimLine Pro model range can also be easily installed without additional fixing materials such as bolts, screws or nuts. Depending on the size of the appliance, it can be installed by one person in just a few minutes. During installation, the appliance is suspended from its rear brackets in the trapezoidal cut-out and secured using integrated quick-fit clips. All models are equipped with integrated condensate evaporation and can be operated in a temperature range from -40 to +60 °C. The IP56 rated units are suitable for indoor and outdoor use in accordance with NEMA type 3, 3R, 12, 4 and 4X, depending on the version. An electronic control system ensures energy efficiency. The color display makes it easy to set and read the operating parameters. In addition to the standard version with powder-coated sheet steel housing, the CE, cURus and RoHS-certified cooling units are also available in a corrosion-protected stainless steel version for harsh and hygienically demanding areas of application.
24 of 25
