According to the supplier, the signal lights in the Tilted Diamond+ series from Rafi offer special brightness, vibration resistance, maintenance-free operation and an unusual lens design: the name Tilted Diamond refers to the diamond-shaped lenses in the lens, which create a special scattered light effect. In order to achieve perfect illumination, the refraction of the lenses has been specifically optimized. Thanks to the uniformly high visibility over 360°, the signal light is easy to see even over long distances. Inside the lights, which are available with the lens colors red, yellow, green, blue and transparent/white, four LEDs with a power consumption of just 0.63 W ensure maintenance-free operation for up to 50,000 hours. Fastening is done with two screws, which can be done from inside or outside the housing. For connection to the 24 V (AC/DC) power supply, the signal lights are optionally available for direct wiring with cage clamp terminal connections or with a 4-pin M12 plug. With a mounting height of 70.1 mm (cage clamp) or 83.55 mm (M12), the signal lights are designed for a temperature range of -30 to +60 °C and feature IP65 and IP67 protection on the front.
