14 of 25
Extended HL top-hat rail enclosure series from Richard Wöhr
© Richard Wöhr
Richard Wöhr is expanding its enclosure range with additional versions of the HL top-hat rail enclosure series. In addition to the previously available 6-module version, there are now 2, 4 and 9-module versions. The enclosures differ only in their width and are supplied as standard in PC (UL94-V0) in light grey (RAL 7035). The lower part is made of PPO (UL94-V0) in black (RAL 9005) and has a snap-in design. This allows it to be quickly mounted on a DIN rail EN 60715 TH35. Standard widths of the housing versions are 35 mm (2-module), 70 mm (4-module), 105 mm (6-module) and 157 mm (9-module). A closed version, suitable clamps or packaging and transparent covers are available as accessories. User-specific holes, surfaces or labels and stickers are available on request.
14 of 25
