13 of 25
Electronic enclosures from the BoPad series from Bopla Gehäuse Systeme
© Bopla Gehäuse Systeme
The electronic housings in the BoPad series from Bopla, which are used to integrate membrane keyboards, touchscreens and displays, have been specially designed to meet the requirements of mobile hand-held operating devices. There are also variants for desktop applications or accessories for wall mounting. The enclosures are available in five basic sizes in black and white, and special colors are also available on request. Users can also choose between console-shaped or straight enclosure versions as well as variants with or without a battery compartment. The BOP 7.0 and BOP 10.1 housing versions have been optimized for the integration of touchscreens and standard 18650 Li-ion batteries. To integrate the membrane keypads and touchscreens, all manual and console enclosures have a lowered surface in the top section. All enclosures offer IP40 protection as standard, which can be upgraded to IP65. Colored impact protection is optionally available for the hand-held enclosures. A VESA standard wall mount is available as an accessory for use as a wall-mounted enclosure. A special latching mechanism enables a compact design that allows a wall clearance of just 7 mm.
13 of 25
