Pepperl+Fuchs supplies various products in different ignition protection types and housing variants for controlling machines and setting up electrical networks in hazardous areas. For example, there is an extensive range of switches, illuminated pushbuttons and emergency stop buttons with a shallow installation depth. Thanks to their bayonet lock, they can be safely installed in any switch panel. The switches are Ex e certified for use in standard enclosures, even in potentially explosive atmospheres.
