12 of 25
CombiTac 6 GHz coaxial module from Stäubli Tec-Systems
© Stäubli Tec-Systems
The CombiTac 6 GHz coaxial module from Stäubli enables the connection of 50 Ω RG coaxial cables via a crimp or SMA connection. Two 2.4 GHz versions with crimp connection are available - one for RG58 cables and one for RG316/U, RG174 and RG188 cables. The SMA version allows connection to any 50 Ω RG cable up to 6 GHz such as RG58, RG316/U, RG174, RG188, RG196, RG213 and RG223. Both the crimp and SMA versions are designed for industrial, broadcast, aerospace and defense applications that require high resistance to shock and vibration. The coaxial modules are also suitable for rail transportation as they comply with current fire and smoke protection requirements. Due to the modular design of the module, each crimp or SMA connection can be easily removed or inserted into the coaxial carrier individually and without tools, without having to dismantle the entire connector.
12 of 25
