With a brightness of up to 700 lm and thanks to its input voltage range of 24 to 265 V(AC/DC), the LEX-350 LED switch cabinet light from Elmeko can be used universally and internationally. The swivel-mounted light, which is available with or without a motion detector, has plug-in connections for the supply line and connection of a maximum of ten units. Despite the low power consumption of just 5 W, it provides 700 lm luminous flux with a color temperature of 5000 K. Its unbreakable plastic housing measures 350 mm x 30 mm x 40 mm (L x W x H). Thanks to the integrated optics, the control cabinet is evenly illuminated over the entire height down to the floor. The light can be switched on and off at the touch of a button using the multifunction button. The light switches off again automatically after one hour. A long press of the button switches it on permanently and can be switched externally via the supply cable or via a door position switch, for example. Equipped with a motion detector, the light switches on automatically in standard mode when the enclosure door is opened. The light is mounted without tools on flat surfaces using magnets or two mounting clips. The LED light is insensitive to shocks and vibrations and works in a temperature range of -20 to +60 °C.
