3 of 15
35_e-chain from Igus
© Igus
With the E4.1L, Igus offers what it claims is the easiest to fill e-chain on the market. A special divider system simplifies the individual internal division of the energy chain for the user. The energy chain is easy to open from all sides and can be filled as required. With the divider system, shelves can be easily inserted over several levels to divide the interior as required. In addition, the hinged mechanism of the opening bars in the outer and inner radius enables quick filling with cables and hoses. The captive bars, which can be opened with a screwdriver, can be swung open by 115° and lock into their end position. If required, they can also be completely removed, reinserted and closed by simply pressing them shut. Rounded edges on the opening and separating bars of the chain also ensure a long service life for the hoses and cables. The grid and positioning scale ensure the best possible distribution of the energy chain.
3 of 15
