Hy-Line Technology
Transmitting high-speed data and power
© Hy-Line
Hy-Line has expanded its USB extender product family with the USB-C hybrid cable 'USC-CC32'. It enables the connection between server computer and HMI up to 4k resolution.
Conventional cables from USB type C plug to C plug are limited in length to around 1 m. In contrast, the new hybrid cable from Hy-Line transmits 10 Gbps super-speed data bidirectionally via fiber optics and power for remote devices via integrated copper wires without interference. The single-cable solution can deliver 100 W at 10 m or 60 W at 15 m. The DisplayPort Alt mode 4K@60Hz is supported on two DisplayPort lanes with 8.1 Gbps/lane each. The hybrid cable is also compatible with USB 2.0 and 1.1 standards. USC-CC32 supports all functions simultaneously. The plug-and-play solution from USB type C plug to C plug requires no external power supply. The entire electronics are housed in the slim connector housing and prevent ESD, EMI and RFI. The connection terminal with its curved design ensures that no interference occurs when connecting to devices such as monitors. Protection against unintentional disconnection of the cable is provided by the optional locking device, which can be attached to the housings of the host and devices with a screw.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
Igus
Billion in sales maintained
Despite the challenging geopolitical and economic situation in 2024, Igus was able to increase the number of active customers by 5%. With sales of € 1.105 billion, the company recorded a comparatively moderate decline in sales of 2.5%.
