Plow
Ex cable gland program expanded
The 'LevelEx' Ex d cable glands from Pflitsch offer a compact design, captive parts and a range of applications for Ex d, Ex e and Ex t equipment class II in the areas of gas and dust.
© Plow
The cable gland consists of just four parts: The sealing elements are designed to be captive, meaning they cannot be lost during installation. When the pressure screw is tightened, the seal is deformed over a large area and achieves a high level of tightness with protection classes IP66 and IP68. According to Pflitsch, large wrench flats enable secure installation using standard tools. A defined deformation of the O-ring - positioned in a groove - ensures a secure seal between the cable gland and the housing when the double nipple is screwed on.
The cable gland is available in sizes M16 to M75 or with NPT threads from 3/8 inch to 2 ½ inch. The cable gland body is made of bare brass, galvanized nickel-plated brass and corrosion-free stainless steel. Cables from 7 to 66 mm can be reliably sealed. The temperature range is specified as -60 to +130 °C.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
