Sagittarius
Enclosure products for North America
Lütze offers switch cabinet products certified to the UL-50E standard for use on the North American market.
© Sagittarius
Lütze 's enclosure products certified to the UL 50E standard include USB and RJ45 installation boxes and the 'Cablefix' feed-through systems for cables and wires. The 'X' and 'One' cable entry systems, tested in accordance with UL ratings types 4X, 12 and 13 for prefabricated and non-prefabricated cables respectively, offer a wide range of clamping ranges from 3.5 mm to a maximum of 29.5 mm and are oil-resistant. Panel boxes for front mounting are available either as an RJ45 connection with Cat.6a or alternatively with a USB 3.0 interface. In addition to a wide range of different types of protection, such as IP65, both flush-mounted boxes comply with UL Type 4X.
Friedrich Lütze
Easy to use
According to the supplier, the new Cat. 6A module carriers from Lütze allow data transfer points between the field and the control cabinet to be implemented more quickly and securely. One of the key features of the module rack is the significantly...
Sagittarius
Turn four into one
Intelligent, digitally networked systems are the hallmark of Industry 4.0, whose largely self-organized production is based on constant interaction between people and machines. Single Pair Ethernet is a good basis for this.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
