Ilme
EMC connectors for drive systems
Ilme launches compact EMC connectors for drive technology.
© Ilme
EMC-protected, compact and quick and easy to connect - these are the properties that plug connections for drive technology for frequency inverters and motor starters must have as a prerequisite. Equipped with an optimized cable connection and direct PE contacting between insert and housing, the CQA / MQA housings from Ilme minimize the effort required for assembly. Thanks to a housing design that conforms to the Desina standard in accordance with ISO 23570-3, the connectors are particularly suitable for drive systems. Various contact inserts for power transmission up to 16 A and 500 V round off the range and make the connector compatible with existing conveyor technology systems.
