Multi-IO modules
Digital and analog in one module
The IO 011 multi-IO module adds a mix module to the S-Dias control system from Sigmatek. With a width of just 12.5 mm, 14 digital I/Os and two analog inputs provide a variety of input and output options.
By combining digital and analog I/Os in one module, users can save control cabinet space. The multi-I/O module has six digital inputs with an input current of 3.7 mA and an input delay of typically 0.5 ms. Eight digital outputs are also integrated, which are short-circuit-proof and designed for 0.5 A. The outputs can be read back and can also be used as inputs. In addition to the digital I/Os, an analog voltage input (±10 V(DC) with 16-bit resolution) and an analog current input are integrated. The latter is designed for measuring ranges from 0 to 20 mA or 4 to 20 mA with a resolution of 16 bits. The module can be programmed and configured using the object-oriented engineering tool Lasal.
