Housing
Quelle: Bopla Gehäuse Systeme | Inka Krischke,
Designed in protection class IP65
Bopla has two new variants of the 'BoTouch' enclosure series: BoTouch BTK-IP 4.3 and BTK-IP 10.1 are designed for the installation of commercially available 4.3 and 10.1 inch capacitive touch displays.
© Bopla housing systems
According to the manufacturer, a finer alignment between the display and housing results in a significantly narrower display frame. Protection class IP65 is achieved by providing the rear of the housing with a foamed PU seal and closing it with a back plate. The glass front is also glued into the housing. As a panel mounting enclosure, 'BoTouch BTK-IP' also has a foamed PU seal in the front frame. The 'Filotec' product line is also suitable for the embedded sector thanks to its heat sinks. With a new size of aluminum profile housing (F 1632-xxx), the manufacturer is meeting the requirements of users who also want to install large-format PCBs. The internal dimensions of the enclosure are designed for the installation of a Eurocard (100 mm × 160 mm) in landscape format.
Friedhelm Loh Group
Managing Board expanded
The Friedhelm Loh Group is aligning its group of companies for the future and is expanding its Executive Board to include Prof. Dr. Niko Mohr. He joins owner and CEO Prof. Dr. Friedhelm Loh and CFO Ralph Lindackers on the Executive Board.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
