Conec Electronic Components
Efficient cabling with hybrid connectors
According to Conec, the hybrid connector series offers the right connector for almost every performance class thanks to its various sizes (B12, B17, B23, B40).
© Conec
With the angled B23 hybrid flange, it is also possible to equip servo drives with an output of over 20 kW with a single-cable solution. By rotating the cable outlet in 18 steps, the flange can be adapted to the respective installation situation in the machine. Common to all sizes is the separately shielded 4-pole data element for the transmission of Industrial Ethernet in accordance with ISO11801 Class D or alternatively signals with currents of up to 4 A. In addition to the 4-pin data element with Ethernet/Ethercat protocol, it is also possible to equip the data element as a dummy module, for example for use as a pure power connector, or with a 2-pin insert for 2-wire bus protocols. In future, the hybrid connectors will be certified in accordance with IEC 61076-2-118. The connector is locked with a bayonet quick-release fastener.
Rosenberger OSI
LWL in a harsh environment
Until now, there have often been concerns about reliability and manageability when using fiber optic cables (FO) in harsh environments. However, current plug contacts also enable safe fiber optic connections in industrial environments, aviation and...
Binder
Compact design with mounted strands
Binder is expanding its M12 portfolio to include flange connectors with a continuous M12×1 mounting thread, which are now equipped with mounted stranded wires. In addition to the previously available dip soldering variants, this version is now...
Lapp
New outfit for rectangular connectors
The previous design of the Epic rectangular connector housings from the HB and HA series dates back to the 1960s - basic geometry and therefore quite angular. Lapp is now launching a smart redesign on the market.
