dtm group
Certified to IP54
The dtm group is expanding its solution portfolio to include modular data cabinets for harsh IT environments: The standard open STV40/45n floor-standing distributors and 40/45U server racks are also available as closed systems with sealed side panels, doors, shelves, ceiling panels and plinths.
© dtm
Certified to IP54, the enclosure systems offer protection against dust and splash water. The server racks are equipped with integrated cable trays and can be combined with gas extinguishing systems and various air conditioning solutions such as side coolers. Power consumption, temperature and similar parameters can optionally be monitored with the manufacturer-independent 'EnviMonitor' monitoring system. This makes the dtm server racks suitable for industrial and office environments as well as for data centers and smaller edge locations.
The components of the IP54 extension are backwards compatible with the existing system and can also be retrofitted. The data racks have a modular design and allow the depth to be extended from 270 to 830 mm to a maximum of 1,430 mm.
B&R
More space in the switch cabinet
The Acopos P3 servo amplifier from B&R is also available with a through-hole cooler or cold plate cooling. According to the manufacturer, these new cooling variants allow up to 60% of the heat loss to be dissipated into the ambient air outside...
Friedhelm Loh Group
Managing Board expanded
The Friedhelm Loh Group is aligning its group of companies for the future and is expanding its Executive Board to include Prof. Dr. Niko Mohr. He joins owner and CEO Prof. Dr. Friedhelm Loh and CFO Ralph Lindackers on the Executive Board.
