Conta-Clip
Also with push-in connection
Conta-Clip now also offers the DIN rail relay bases of the 'PRS' plug-in relay system in versions with push-in connection.
Thanks to the tool-free wire insertion, the sockets in the new PPRS series, which are available for relays with 1, 2 or 4 changers, significantly reduce the time required for wiring, according to Conta-Clip. Integrated pushers, which can be operated without special tools, are used to release the inserted wires. The relay sockets are designed for a rated voltage of 300 V and can be flexibly configured with PRS relays for voltage ranges from 12 to 220 V(DC) or 12 to 230 V(AC) as well as the corresponding plug-in modules with LED status display. Each connection also has a test tap for easy checking of the voltage applied. The pluggable and touch-proof external cross-connection system 'AQI/PPRS' is available as an accessory for the demand-oriented distribution of potentials between bayed base modules. Other equipment options include snap-on retaining brackets that hold the plugged-in relays in place if required.
