Agro
New EMC multiple feedthrough
© Agro
The cable gland supplier Agro, part of the Kaiser Group, is expanding its 'MCE' multiple entry system for shielded cables and wires with new EMC versions.
The EMC variants from Agro consist of two corrosion-resistant and impact-resistant aluminum half shells in six variants with three or eight feed-throughs for cable clamping ranges from 6 mm to 21 mm. For a secure, powerful shield pick-up with low transfer impedances, the units have contact springs from the 'Easyconnect' series, which compensate for tolerances in the shield thicknesses. The special shape of the contact spring results in a large shield clamping range. Circumferential rubber flat seals made of CR and NBR enable tightness up to IP69k. In addition to NBR rubber molded elements in an easy-to-install, slotted design, flexible multilayer seals that can be adapted to different cable diameters are also available as sealing inserts. Customized sealing units, for example with multiple bores, are also available. Unused bushings are sealed with solid rubber sealing inserts. The highly robust, salt spray-tested multiple bushings in accordance with ISO 9227 are suitable for use in temperature ranges from -30 to +105°C, offer strain relief in accordance with EN 62444 (type A) and are REACH and RoHS compliant.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
ZVEI
Rittal wins Electrifying Ideas Award 2026
The ZVEI has chosen Rittal as the winner of the Electrifying Ideas Award 2026. With this award, the German electrical and digital industry honors innovations and solutions that use energy efficiently, conserve resources and have an economic and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Lapp
Asia strong, Europe weak
The Lapp Group achieved sales of 1.93 billion euros in the past 2025 financial year (October 1, 2024 to September 30, 2025). Driven by growth in Asia and America, the Stuttgart-based family-owned company is thus compensating for its decline in sales...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
