I/O distributors
Active logic functionality onboard
Escha markets new M8x1 I/O distributors with active logic function in different versions. The devices put intelligence close to sensors, and convey ready processed signals to a central controller unit.
© Escha
Given compactness and low weight, these I/O distributors are especially suitable for applications in tight corners like grippers, robots, or handling units. With multiple attachment boreholes the distributors can work in-built in different situations. Labeling on all slots simplify marking and assignment. The M8x1 I/O distributor comes with active logic in 4-way, 8-way, and 10-way versions, with different fixed combinations of AND and OR logic. Fixed specified logic means devices need no user programming, and are immediately ready for use. A signal status indicator per channel plus LED indicator for logic output provide fast overview of major functions. All distributors satisfy IP65 and IP67 tightness grades.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
